Hi guys,
it would like to have two properties working un this way in data card:
if in the property 1 I select from list the item A -> in the property 2 I can only select B, C or D from list
or
if in the property 1 I select from list the item X -> in the property 2 I can only select Y, W or Z from list
I mean category and sub category
category A -> sub category B,C,D
category X -> sub category Y,W,Z
e.g.
category A = hydraulics
sub category B= pipe
sub category C=valve
sub category D=hose
Any help will be appreciated.
Hi Raminasrl,
It seems that it is a common programming issue rather than Vault API related. You may get more responses in other sites like stackoverflow.com. If this is vault API specific question, would you please help me to understand you clearly with more detailed information?
