Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Properties selection list category and sub category
1 REPLY 1
305 Views, 1 Reply
Hi guys,
it would like to have two properties working un this way in data card:
if in the property 1 I select from list the item A -> in the property 2 I can only select B, C or D from list
or
if in the property 1 I select from list the item X -> in the property 2 I can only select Y, W or Z from list
I mean category and sub category
category A -> sub category B,C,D
category X -> sub category Y,W,Z
e.g.
category A = hydraulics
sub category B= pipe
sub category C=valve
sub category D=hose
Any help will be appreciated.Smiley Happy
1 REPLY 1
Daniel.Du
Hi Raminasrl,
It seems that it is a common programming issue rather than Vault API related. You may get more responses in other sites like stackoverflow.com. If this is vault API specific question, would you please help me to understand you clearly with more detailed information?
Daniel Du
Developer Technical Services
Autodesk Developer Network
