Hello Guys,
I need to store extra data along with file properties.
Ex:
For inventor File i have something called as CutomProperties where i can store new/custom data which save along with file.
Can i have custom data stored along with file properties in vault?
Thank You
Solved by minkd. Go to Solution.
You can have custom properties on files, folders, items & change orders.
You can have file attachments on files, items and change orders.
-Dave
If you have a custom iProperty in an Inventor file, you should be able to map it to a custom property in Vault. See the "Property Mapping" page in the Vault help.
Thank You for your reply
Redmond : I just gave an example of iProperties but will not be using iproperties.
Dave Mink:
I need to store extra data like a "hyperlink" to the file properties. Not only this some more data with the file.
Is there any sample ?
I'm not sure why you wouldn't want to use a property for something like a hyperlink to data in another system.For a file attachment, both the file being attached and the entity is being attached to must reside in the vault.
-Dave
