Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
How to login to VDF with AutoLogin
4 REPLIES 4
Micky_SDP
708 Views, 4 Replies
Hi all,
I would like use the AutoLogin checkbox.
If Autologin is checked the Login form should not be displayed and the login should be automatic.
It is possible?
Thank's
Michele
4 REPLIES 4
Redmond.D
in reply to: Micky_SDP
Yes.  To use the auto login feature, you need to provide LoginSettings.  The AutoLoginMode property determines how you want auto login to work.  You should also provide a PersistenceKey, so that the saved settings are unique to your app.
Doug Redmond
Software Engineer
Autodesk, Inc.
Micky_SDP
in reply to: Redmond.D
Thank's Redmond.
But it is possible find the value of current AutoLoginMode property of Vault Client?
Thank's...
Michele
Redmond.D
The intent is for each app to have their own settings.  There is no API suppoprt for reading another applications Vault login settings.
Doug Redmond
Software Engineer
Autodesk, Inc.
Micky_SDP
Sorry Doug,
but I still have a doubt...
It is not possible to know if auto login to next session is enabled on Vault by code? There is this information?
Thnak's
Michele
