Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
How I get email content from Autodesk.Connectivity.WebServices.File
1 REPLY 1
wesbird
350 Views, 1 Reply
  I just start learning Vault programming.
  from HelloWorld example code, after I got
  File selectedFile
  if it's email, how I can email subject, sent by, content, etc. should I download the file first? where I can find a example code?
Thanks you so much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
Redmond.D
in reply to: wesbird
If those properties are stored in Vault, then you can read them by calling Connection.PropertyManager.GetPropertyValues.  Unfortunately, I don't have any samples onhand for this function.  Let me know if you get stuck.
If those properties are not stored in Vault, then you will need to download the file and read that infromation directly from the file.  If it's an Outlook file, then there are probably Micrsoft APIs that can read that information.
Doug Redmond
Software Engineer
Autodesk, Inc.
