I just start learning Vault programming.
from HelloWorld example code, after I got
File selectedFile
if it's email, how I can email subject, sent by, content, etc. should I download the file first? where I can find a example code?
Thanks you so much
Wes
Solved by Redmond.D. Go to Solution.
If those properties are stored in Vault, then you can read them by calling Connection.PropertyManager.GetPropertyValues. Unfortunately, I don't have any samples onhand for this function. Let me know if you get stuck.
If those properties are not stored in Vault, then you will need to download the file and read that infromation directly from the file. If it's an Outlook file, then there are probably Micrsoft APIs that can read that information.
