Hi
I found GetChangeOrderNumberBySchemeId will increase the number, just like SEQUENCE in database. Is there a way I can get the number without increasing?
Thank you so much
Wes
Solved by wayne.brill. Go to Solution.
Hi Wes,
The numbering scheme engine used by ChangeOrders is also used by Items and Files, so they all have the same limitations. Once the number has been generated there is no way to roll it back, or reset the seed. However, the AddChangeOrder/UpdateChangeOrder methods allow for change orders to use any desired string for the change order number – it just must be unique.
Wayne
