Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
GetChangeOrderNumberBySchemeId increase number
1 REPLY 1
wesbird
326 Views, 1 Reply
Hi
  I found GetChangeOrderNumberBySchemeId will increase the number, just like SEQUENCE in database. Is there a way I can get the number without increasing?
Thank you so much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
wayne.brill
in reply to: wesbird
Hi Wes,
The numbering scheme engine used by ChangeOrders is also used by Items and Files, so they all have the same limitations.  Once the number has been generated there is no way to roll it back, or reset the seed. However, the AddChangeOrder/UpdateChangeOrder methods allow for change orders to use any desired string for the change order number – it just must be unique.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
