Hello
A simple tip in order to stop JobProcessor.
Execute the following command:
TASKKILL /IM JobProcessor.exe /F
Put this command line in a *.bat file and schedule its execution via Task Scheduler.
Useful especially when you have setup a "batch machine" and you don't want to have jobprocessor continuously running in background sucking a license token.
Only issue, i see till today: kill Job Processor like this, can produce an error if it effectively converts a file when the kill-script is executed.
This tip will be obsolete when Autodesk will provide finally a command line option to stop Job Processor in a clean way
Aurélien
Solved by Mark_Wigan. Go to Solution.
& some more commands for anyone who happens to fly buy this post...
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0001-Using_Va1/0031-Manage_t31
Hello
First, thank you for this command line options, which are actually not optional 😉
In which version of jobprocessor, these command are implemented ?
Aurélien
The Pause, Resume and Stop command line options were added for the Vault 2013 release.
hi Doug,
thanks for your reply.
would your team be able to consider making the 3 new commands also available for version 2012?
i know it is a hassle but i have clients on different versions. considering this command line functionality is necessary for this job prcessor to work after hours i think it is really worth asking the question.
many thanks!
