Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Exiting Job Processor ///Tip
4 REPLIES 4
aurelien.berthelot
983 Views, 4 Replies
Hello
A simple tip in order to stop JobProcessor.
Execute the following command:
TASKKILL /IM JobProcessor.exe /F
Put this command line in a *.bat file and schedule its execution via Task Scheduler.
Useful especially when you have setup a "batch machine" and you don't want to have jobprocessor continuously running in background sucking a license token.
Only issue, i see till today: kill Job Processor like this, can produce an error if it effectively  converts a file when the kill-script is executed.
This tip will be obsolete when Autodesk will provide finally a command line option to stop Job Processor in a clean way Smiley Wink
Aurélien
4 REPLIES 4
& some more commands for anyone who happens to fly buy this post...
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0001-Using_Va1/0031-Manage_t31
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
Hello
First, thank you for this command line options, which are actually not optional 😉
In which version of jobprocessor, these command are implemented ?
Aurélien
The Pause, Resume and Stop command line options were added for the Vault 2013 release.
Doug Redmond
Software Engineer
Mark_Wigan
in reply to: Redmond.D
hi Doug,
  thanks for your reply.
would your team be able to consider making the 3 new commands also available for version 2012?
i know it is a hassle but i have clients on different versions. considering this command line functionality is necessary for this job prcessor to work after hours i think it is really worth asking the question.
many thanks!
best regards,
- Mark
