Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Edit of unmapped UDP (File Property)
6 REPLIES 6
gluckett
890 Views, 6 Replies
HI All,
I have a UDP on a file that is currently blank.  I know its ID (84) and have the file's MasterId.
Example:
serviceManager.DocumentService.UpdateFileProperties(New Long() {file.MasterId}, New Long() {84}, New String() {"My Custom Property Is now populated"})
Do I need to send my String in a different way?  Perhaps as an Object?
6 REPLIES 6
Redmond.D
in reply to: gluckett
The code looks OK to me, but I'm guessing it's not working for you.  Can you describe the problem more?  Are you getting an error?  If so, what is the error code?
Doug Redmond
Software Engineer
gluckett
in reply to: Redmond.D
Doug, yes here is a bigger snippet of the code, I can update the Category but not the UDP
            For Each file As Autodesk.Connectivity.WebServices.File In files
               If parentFolder.FullName = "$/MYTESTFOLDER" Then
                    'Setting the File Category works great...
                    serviceManager.DocumentServiceExtensions.UpdateFileCategories(New Long() {file.MasterId}, New Long() {"37"}, "")
                    'This fails...
                    serviceManager.DocumentService.UpdateFileProperties(New Long() {file.MasterId}, New Long() {"84"}, New String() {"My Update"})
                End If
            Next
The error on the UpdateFileProperties is "SoapException: 1136" - I don't get any errors when updating Categories...
minkd
In order to update properties the file must be checked-out first.
-Dave
Dave Mink
Fusion Lifecycle
gluckett
in reply to: minkd
That did the trick!  I checked out, changed the UDP and checked in.
  Dim out As ByteArray
 serviceManager.DocumentService.CheckoutFile(parentFolder.Id, file.Id,
                               CheckoutFileOptions.Master,
                               Environment.MachineName,
                               "c:\temp\", "",
                           DownloadOptions.Download,
                                    False, out)
serviceManager.DocumentService.CheckinFile(file.MasterId, "", False, Today, Nothing, Nothing, True, file.Name, file.FileClass, file.Hidden, out)
spascual
Hi Sirs,
Anybody knows if for vault 2022 same process works?
gluckett
in reply to: spascual
Haven't tried with 2022, but the API hasn't changed that much...
