Hi All. Im for a drawing register (access, xls, standalone app, etc) that will enable me to link to data inside the Vault. So, if you have an external file, like a spreasheet, that lists all your drawings with their revisions, etc. We can create a hyperlink, that links text to an Inventor orAutoCAd Drawing in Windows Explorer.
Can this be done, so that it can be linked to data, inside the Vault....?
Chris
As I understand you properly you need in unique Vault identifier that could be saved in your spreadsheet for every drawing document.
I think you may consider using File.Id and/or File.MasterId identifiers.
They are
So they could be easily used to get access to the specific version of the file or the most fresh one via your own external.
We do not support the external persistence of File IDs or File Master IDs.
If you need a persistent identifier for an entity, you should use the GetPersistentIds() method of the KnowledgeVaultService. You can then convert it back to a file ID using the ResolvePersistentIds() method.
-Dave
