Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
DownloadFile.
4 REPLIES 4
411 Views, 4 Replies
DownloadFile.
I made a program for Vault 2013. Unfortunately it don’t work for Vault 2014. I’ve tried to figure out how to rewrite it to 2014, but I struggle. The problem is DownloadFile that has been removed from WebServices. I had the lines below in my code. It should get a file from Vault by Id and save the file in the folder “c:\Vault export\” outside our local Vault area. Any tip on how I should rewrite it would be appreciated.
docSrv.DownloadFile(oFileAssoc.ParFile.Id, True, oBytes)
System.IO.File.WriteAllBytes("C:\\" + "Vault export\" & oFileAssoc.ParFile.Name, oBytes.Bytes)
4 REPLIES 4
Redmond.D
in reply to: Redmond.D
Thanks.
But if I got a fileid for instance 2591234 how do I convert it to an ICollection so that I can use the sub
Public Sub DownlodFiles(fileIters As ICollection(Of VDF.Vault.Currency.Entities.FileIteration))
I found a method.
Imports Framework = Autodesk.DataManagement.Client.Framework
        Dim lFileIds(0 To 0) As Long
        lFileIds(0) = lIndex
        Dim oFiles As Autodesk.Connectivity.WebServices.File()
        oFiles = m_conn.WebServiceManager.DocumentService.GetFilesByIds(lFileIds)
        Dim FileList As List(Of Autodesk.Connectivity.WebServices.File)
        FileList = New List(Of Autodesk.Connectivity.WebServices.File)()
        If (Not lFileIds Is Nothing) Then
            FileList.AddRange(oFiles)
        Dim oFileIteration As Framework.Vault.Currency.Entities.FileIteration
        oFileIteration = New Framework.Vault.Currency.Entities.FileIteration(m_conn, FileList(0))
Redmond.D
That code works, but there is an easier way.  You can call m_conn.FileManager.GetFilesByIterationIds(...)
Doug Redmond
Software Engineer
Autodesk, Inc.
