I'm writing a program to download and checkout files using acquire. How to I get the files downloaded to the working folder in the correct folder structure? I only manage to download them to "Application.LocalUserAppDataPath" as in the VaultList example by Wayne Brill.
http://adndevblog.typepad.com/manufacturing/2013/06/checkout-checkin-a-file-in-vault-2014.html.
I would like to replicate the double click function on a file in the Vault client.
Thank you.
/Dan
Solved by Redmond.D. Go to Solution.
By default, AcquireFiles downloads to the working folder. Wayne's sample seems to be setting the local folder explicitly, which overwrites the default behavior.
Here are some things to try:
