Vault Customization
Valued Contributor
Message 1 of 5 (268 Views)
DocumentService AddFileEvents.Post not firing
268 Views, 4 Replies
11-05-2012 09:44 AM
Hi
i have created a IWebServiceExtension for vault collaboration 2013.
DocumentService AddFileEvents.Post works fine when used from vault explorer client. if i add a file my code runs and update file properties.
But when i add a file(checkin) from Autocad 2013 application using the vault client ribbon bar no event trigger i even tried the post checkin event nothing happning.
any help how i can hook in to post add or checkin event no mather what the client app is.
thanks
Nav
Employee
Message 2 of 5 (264 Views)
Re: DocumentService AddFileEvents.Post not firing
11-05-2012 02:04 PM in reply to: mnav
First, make sure that your extension is loading.  http://justonesandzeros.typepad.com/blog/2012/07/extension-loading-error-logging.html
Keep in mind that AutoCAD doesn't have the same DLL set that Vault Explorer has.  If AutoCAD can't load all the DLL references, the extension can't load.
Put a breakpoint in the OnLoad() funciton to verify that your extension is truely being loaded and executed.
Doug Redmond
Software Engineer
Valued Contributor
Message 3 of 5 (247 Views)
11-06-2012 07:59 AM in reply to: Redmond.D
Hi Doug
thanks for your reply. i have copied all reference dlls in same folder the extention is but still having the same issue.
the loading error log give this info.
can you pls let me know how to debug from autocad vault client. every time i attch my project to autocad for debug it hangs and goes into not responding mode.
06/11/2012 15:52:48 ******************************************************************************
Autodesk.Connectivity.Extensibility.Framework Error: 1 : System.IO.FileLoadException: Could not load file or assembly 'Autodesk.Connectivity.Explorer.Extensibility, Version=17.0.0.0, Culture=neutral, PublicKeyToken=aa20f34aedd220e1' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: 'Autodesk.Connectivity.Explorer.Extensibility, Version=17.0.0.0, Culture=neutral, PublicKeyToken=aa20f34aedd220e1'
   at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.AppDomain.Load(AssemblyName assemblyRef)
   at Autodesk.Connectivity.Extensibility.Framework.AssemblyChecker.FindAssembly(AssemblyName reference)
   at Autodesk.Connectivity.Extensibility.Framework.AssemblyChecker.CheckAssemblyRecursive(Assembly assembly)
   at Autodesk.Connectivity.Extensibility.Framework.AssemblyChecker.CheckAssembly(Assembly assembly)
   at Autodesk.Connectivity.Extensibility.Framework.ExtensionLoader.LoadExtension(Extension ext, ExtensionTypeEnum extType)
   at Autodesk.Connectivity.Extensibility.Framework.ExtensionLoader.LoadExtensions(ExtensionTypeEnum extensionType)
thanks.
nav
Valued Contributor
Message 4 of 5 (243 Views)
11-06-2012 08:32 AM in reply to: mnav
resolved the issue by updating the autocad vault clients dlls with the ones from vault sdk bin folder.
still dont know  how to debug from autocad vault client. every time i attch my project to autocad for debug it hangs and goes into not responding mode. Debugger.Launch() or break dnt work too.
any help.
thanks
Nav
Employee
Message 5 of 5 (228 Views)
11-07-2012 04:52 AM in reply to: mnav
Debugging Autocad is a bit harder since it is not a .NET exe.  However it shouldn't be hanging on you.
I suggest playing around with the debug options a bit.  For example there is an option for debugging managed code, native code and both.  I have never gotten the "both" option to work.  You want "managed" if you want active breakpoints in .NET code.
If you still can't get it to work, ask around on the AutoCAD programming forums.
Doug Redmond
Software Engineer
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
