Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
DLL Configuration Setup Question
3 REPLIES 3
meck
498 Views, 3 Replies
In the configuration file of a DLL, is it possible to have 2 different extension types at the same time? I'd like to be able to create menu items and also trigger from change order events. To create the menu I need <extensionType>VaultClient</extensionType> and to hook into the change order events I need <extensionType>WebService</extensionType>.
Can I do both at the same time or do I have to breakout each functionality into 2 different DLLs?
Thanks in advance.
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
3 REPLIES 3
Daniel.Du
in reply to: meck
I would recommend to separate them.
Daniel Du
Developer Technical Services
Autodesk Developer Network
Balaji_07
in reply to: Daniel.Du
Hi Daniel
Is there any specific reason in having separate config files.
Balaji A
Daniel.Du
in reply to: meck
I thought it is safe to seperate them, but after checking with engineering team, actually it is possible to combine them together, you can have multipul <extension> tag in vcet.config file, as demoed in JobProcessorApiSamples of SDK, the vcet.config is as below:
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<connectivity.ExtensionSettings3>
<extension
interface="Autodesk.Connectivity.Explorer.Extensibility.IExplorerExtension, Autodesk.Connectivity.Explorer.Extensibility, Version=18.0.0.0, Culture=neutral, PublicKeyToken=aa20f34aedd220e1"
type="JobProcessorApiSamples.QueuePublishJobCommandExtension, JobProcessorApiSamples">
</extension>
<extension
interface="Autodesk.Connectivity.JobProcessor.Extensibility.IJobHandler, Autodesk.Connectivity.JobProcessor.Extensibility, Version=18.0.0.0, Culture=neutral, PublicKeyToken=aa20f34aedd220e1"
type="JobProcessorApiSamples.FolderPublishJobHandler, JobProcessorApiSamples">
<setting key="JobType1" value="MyCompany.File.Publish"/>
</extension>
</connectivity.ExtensionSettings3>
</configuration>
Daniel Du
