Is there any way to read from an assembly configuration file (xxx.dll.config) from a Vault Job Processor using the standard method of Properties.Settings.PropertyName?
I attempted to use a config file for NLog in a previous processor that I wrote, but none of the options were read (and thus logging did not work). Before I go down the path of rolling my own configuration, I wanted to check to see if I was doing something wrong or if the options need to be added to the JobProcessor config file instead.
I've only used .exe.config files. I'm not sure if there is such a thing as .dll.config files. You will have to look at the .NET documentation from Microsoft to find out more.
I don't suggest adding your own content to JobProcessor.exe.config. That's a component installed with the Vault client. An update or hotfix may overwrite your change. In my plug-ins, I usally just load the settings file directly from my code.
If you have an addin called addin.dll, you can access its configuration file (addin.dll.config) like this
var executingAssembly = System.Reflection.Assembly.GetExecutingAssembly();
var location = executingAssembly.Location;
var config = ConfigurationManager.OpenExeConfiguration(location);
var sections = config.Sections;
string tempPath = config.AppSettings.Settings["OutputFolder"].Value.ToString();
Hope it helps
Nick
