at the moment i write a little Vault-Addin. This Addin fires a Procedur after the Category of an File has Changed. To do this, i found a Event called PostInvokeEvents in the Class CategoryService.
My Code:
PublicSub OnLogOn(application AsIApplication)
ImplementsIExplorerExtension.OnLogOn
AddHandler application.Connection.WebServiceManager.CategoryService.PostInvokeEvents, AddressOf cat_PostInvokeEvents
EndSub
But after changing the Category of an File there still no Event raised.
Solved by Redmond.D. Go to Solution.
Invoke events only fire when your code changes the file category. There is no event to hook into when other code changes file category.
