Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Calucation value for User Defined Properties
1 REPLY 1
wesbird
482 Views, 1 Reply
  As request, I re-post here.
  I'm working on a new Vault implementation project. I added some UDPs.
  ClientID = List of (3,4,5)
  StartDate = Change Order Open Date
  now I'm wondering if this possible:
  I like to have a new UDP: DueDate which
  if ClientID = 3, then DueDate = StartDate+5 Working Day;
  if ClientID = 4, then DueDate = StartDate+10 Working Day;
  if ClientID = 5, then DueDate = StartDate+15 Working Day;
  if not possible out of box, how about programming?
Thank you,
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
Redmond.D
in reply to: wesbird
There are some custom programming options for doing what you want....
Option 1: Custom Command
Create a custom command which does the opration exactly how you want it done.  For example, you can create your own Start Change Order command which puts the CO in the open state and sets the appropriate due date.  The trick is to get your Vault users to use the custom command instead of the default command.
Option 2: Custom Job Handler
Use the Job Server to set the due date in response to state changes.  This is nice because the software only has to be installed in one place, and it doesn't alter any existing user workflows.  The downside is that it's asynchronous.
Doug Redmond
Software Engineer
Autodesk, Inc.
