I would like to know if it is possible to add a context menu item to the BOM tab within Item explorer. See image.
I experimented with the HelloWorld example in the Vault 2013 SDK. I modified it such that it displays "Hello Item" in the context menu when an item is selected in the top pane.
If I switch to the Bill of Materials tab and select an item, I do not see the Hello Item menu.
If I switch to Where Used to and select an item, I can see it.
Any ideas?
Unfortunately, adding custom commands to BOM is not supported.
You should be using an assignment like this (copied from the HelloWorld sample):
NavigationTypes = new SelectionTypeId[] { SelectionTypeId.File, SelectionTypeId.FileVersion }
Which members of the SelectionTypeId class are you using?
