This may seem like a basic question but I can't seem to find the answer. I'm trying to simply submit a job to the job queue to create dwfs of some newly checked in files.
I know the job type, 'autodesk.vault.dwf.create.dwg', but I don't know the parameters. Is there a list of what parameters are required for each of the built in jobs?
Thanks.
Solved by Redmond.D. Go to Solution.
Queuing up the out-of-the-box job types is not something that's part of the supported API. Therefore, it's not documented. You will have to do a bit of reverse engineering to find the parameters.
I feared this may be the case. Thanks for your assistance.
