Hi
I use rules iLogic for checks in add-in i CHECK IT(Tata technologies).
I have a problem with a add-in for AVP2014 - i CHECK IT(Job processor for Vault). Question is, whenever when I use software bundle AVP2014 - i CHECK IT - Inventor 2014 and model objects AssemblyDocument.ComponentDefinition.Occurrences, AIP2014 crashes with a critical error “An unhandled exception occurred”. When I use bundle i CHECK IT - Inventor 2014 check passes without errors.
Thanks, Alex
It is very difficult for us to suggest a solution because this problem depends on the third-party add-in. So it should be first analyzed with i CHECK IT developers.
Cheers,
