Is there a way of obtaining Vault's credentials from the Inventor API? I'm trying to create a command in my Inventor add-in that needs to login to the vault to gather some infomation. I can create my own login screen if need be but why have the user login again if the credentials can somehow be obtained from Inventor. Also, if I create my own login screen then wouldn't the user be logged in twice (i.e. Inventor normal vault login mechanism plus my login code) which I assume will consume another license?
Solved by Redmond.D. Go to Solution.
There is an old post that tells you how to get this information. As far as I know, the trick still works.
http://forums.autodesk.com/t5/Autodesk-Vault/SecurityHeader-in-Inventor/m-p/1713249/
The code you mention eailer in this thread does not work for 2011 and I can't user the VaultServiceManager to get the SercurityHeader until 2012. Besides the references you've mentioned in an earlier thread, the Security object also requires Connectivity.Proxies.utils to be referenced which I've done. I can't find a reference in any of the loading libraries to ServiceAttributeTest (Object Browser) so I'm assuming it used to be in one of the two libraries that you've said requires referencing (just a guess). In any case, are there any changes I can make to get the SercurityHeader in 2011?
In Vault 2011, the security header you want to use is Autodesk.Connectivity.WebServices.DocumentSvc.SecurityHeader.
In Vault 2010 and earlier, there was no Autodesk.Connectivity.WebServices.dll so each project had to generate their own web service objects. As a result, the namespaces would be different for each project. The original code was from a sample application called ServiceAttributeTest.
Thanks Doug but I need a little more help. Can you explain exactly how (code) to obtain the security header from Inventor? I assume that ServiceAttributeTest class contains the SecurityService object which code can access to obtain the seucrity header to apply to other vault service objects (like DocumentSvc). But how exactly do I extract the security header from Inventor in 2011?
In the code below I've attempt to utilize Rene's code from the thread you've mentioned earlier in this conversation but I receive the following error message. I did have to modify Rene's code because 2011 doesn't seem to have a ServiceManager object any longer.
Imports Autodesk.Connectivity.WebServices Imports System.IO Imports Connectivity.InventorAddin.EdmAddin Imports Connectivity.Proxies.Security Imports Connectivity.Proxies.Utils Public Class EditedOutOfTurn Private moDocSvc As Autodesk.Connectivity.WebServices.DocumentService Private msLocalRoot As String Private Const HOST As String = "L1429783" Private Shared MAX_FILE_SIZE As Long = 50 * 1024 * 1024 ' 50 MB 'Private Sub EditedOutOfTurn_Activated(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Activated Private Sub EditedOutOfTurn_Shown(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Shown Dim oDocument As Inventor.Document Dim sRelativePathFile As String Dim sVaultPathFile As String Dim aoFiles() As Autodesk.Connectivity.WebServices.File Dim oFile As Autodesk.Connectivity.WebServices.File Dim oAllReferencedDocuments As Inventor.DocumentsEnumerator Dim sFile As String Dim c As New CRC32 Dim crc As Integer = 0 ListView1.Items.Clear() 'Shouldn't be necessary because this form is unloaded when done so the Shown event will trigger (triggers only once) moDocSvc = New DocumentService() moDocSvc.Url = "http://" & Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmSecurityContext.RemoteHost & "/AutodeskDM/Services/DocumentService.asmx" moDocSvc.SecurityHeaderValue = New DocumentSvc.SecurityHeader() Dim security As EdmSecurity = EdmSecurity.Instance If security.IsSignedIn() Then moDocSvc.SecurityHeaderValue.Ticket = security.SecurityContext.Ticket moDocSvc.SecurityHeaderValue.UserId = security.SecurityContext.UserID End If Dim sLocalRoot As String If moDocSvc.GetEnforceWorkingFolder Then sLocalRoot = moDocSvc.GetRequiredWorkingFolderLocation If Mid(sLocalRoot, Len(sLocalRoot)) = "\" Then sLocalRoot = Mid(sLocalRoot, 1, Len(sLocalRoot) - 1) Else 'C:\Documents and Settings\UserName\Application Data\Autodesk\VaultCommon\Servers\Services_Security_1_25_2010\l1429783\Vaults\PCI PS Vault\Objects\WorkingFolders.xml 'Vault Version - This one looks a bit strange, for example Vault 2010 has a value of "Services_Security_1_26_2009". It's basically a code that changes with each release. Therefore client settings are tied to a specific Vault version. 'We have 3 working folders (C:\Local Workspace, M:\PCI Inventor Library\Content Center Files, 'M:\PCI Inventor Library\Purchased Components) so an array of these folder should be created 'Also, I came across a user that used to have a local path for our design 'in "C:\Local Workspace\CAD Data" instead of "C:\Local Workspace". '2012 has GetWorkingFolder sLocalRoot = "C:\Local Workspace" End If oDocument = goInvApp.ActiveDocument sFile = oDocument.FullFileName sRelativePathFile = Mid(oDocument.FullFileName, Len(sLocalRoot) + 1) sVaultPathFile = Replace("$" & sRelativePathFile, "\", "/") Dim asFiles2() As String = {sVaultPathFile} aoFiles = moDocSvc.FindLatestFilesByPaths(asFiles2) oFile = aoFiles(0) If oFile.Id = -1 Then 'collect the list of files that could not be found. Else crc = c.GetCrc32(oDocument.FullFileName) If oFile.Cksum <> crc Then ListView1.Items.Add(oDocument.FullFileName) End If oAllReferencedDocuments = oDocument.AllReferencedDocuments() For Each oDoc As Inventor.Document In oAllReferencedDocuments sRelativePathFile = Mid(oDoc.FullFileName, Len(sLocalRoot) + 1) sVaultPathFile = Replace("$" & sRelativePathFile, "\", "/") Dim asFiles() As String = {sVaultPathFile} aoFiles = moDocSvc.FindLatestFilesByPaths(asFiles) oFile = aoFiles(0) If oFile.Id = -1 Then 'collect the list of files that could not be found. Else crc = c.GetCrc32(oDoc.FullFileName) If oFile.Cksum <> crc Then ListView1.Items.Add(oDoc.FullFileName) End If Next End Sub End Class
The error states that the appliation, Inventor, "could not load file or assembly Autodesk.Connectivity.WebServices".
So you need to put a copy of Autodesk.Connectivity.WebServices.dll in a place where Inventor can load it. You can try putting it next to your add in. If that doesn't work, try putting it in Inventor's bin directory.
You da man! Thanks Doug. I've copied it to the add-in folder and now it works.
I'm confused though, the Inventor addin references Autodesk.Connectivity.WebServices.dll from a location beneath My Documents where I have some VB.NET projects. Why can't the Inventor addin use that copy (it know where it's located)?
You'll have to ask the Inventor team why the DLL didn't load from the original location. Loading DLL references is very complex and each appliation gets to set rules about how and where DLLs get loaded.
I seem to be having issues with Connectivity.InventorAddin.EdmAddin.EdmSecurity on Windows 7 64-bit using Visual Basic with dotNet 4.0. I have taken a sample add-in and have added the logic for acquiring the Vault UserID and Ticket information when the user is previously logged in.
Windows 7 64-bit - Vault 2011 - Inventor 2011
MsgBox("IsSignedIn : " & security.IsSignedIn)
MsgBox("Ticket: " & security.GetEdmCCSecurityContext.Ticket)
MsgBox("UserID : " & security.GetEdmCCSecurityContext.UserID)
MsgBox("Host : " & security.GetEdmCCSecurityContext.RemoteHost)
Using dotNet 3.5 under x86 or x64 compile, the logic functions appropriately.
Using dotNet 4.0, the logic always returns EdmSecurity.IsSignedIn is False and accessing the Ticket gives "Object does not reference an instance of an object..." error.
I am wanting to use dotNet 4.0 and I am wondering if this is a known issue with any resolution.
Thanks.
Kevin Mette
I'm pretty sure that even though Inventor 2012 supports .NET 4.0 addins, the Vault SDK dlls only allow .NET 3.5 - at least that's my experience anyway.
Perhaps in the next release they'll allow .NET 4.0??
