Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
3DS MAX high cpu high disk usage
2 REPLIES 2
1382 Views, 2 Replies
Hello!
I used to use 3ds max in 2010 if i remember right (not at home tho) and it worked flawlessly, so now that i need 3d modelling software for my own use, i decided to try newest version first before i even think about buying it. So i downloaded the free trial and it installed without problems, but when i start 3ds max.. thats when the problem starts.
So my problem is this. When 3ds max in on, it uses about 40% of my whole cpu (one core is 100% and three others are 10-30%). I could live with this problem for now, but when i start rendering it would be a nightmare. Worst problem is that when 3ds max is on, it uses my hdd for about 40mb/s. Task manager says name of that process that uses hdd is "system", but if i start my 3ds max now, the problem starts, and when i stop it, the problem stops. I have done this "test" plenty of times, so it have to somehow connected to 3ds max. Oh, and its not becouse i have so much stuff in my 3ds max, the problem starts when i start 3ds max in EMPTY screen. (i havent done anything yet with it).
I have also tried reinstalling it couple of times, it didnt change anything.
My cpu is i5-4670k and hdd in question is OCZ vertex 3 120gb SSD. Both are working without problems, i can play many high-end games without problems and i can render videos without problems also. So i dont think problem lies there.
Anybody have any tips for this problem? i could live with this, but i dont think its supposed to work like this, so better to try and get it working properly.
Tags (3)
2 REPLIES 2
minkd
You will probably get better answers if you posted this to the 3DS Max forum.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
in reply to: minkd
Oh, i thought i did, thanks for the heads up, i'll go there 🙂
