Hi all,
i have create a "WebService" dll with Events AddFile and MoveFile
all works fine because when i change the property i must always start the file prop sync
with this dll can i start the file Property Sync via api?
as example look the picture
thx for help
There is no API function that does the entire prop sync operation. The closest thing is IExplorerUtil.UpdateFileProperties in Autodesk.Connectivity.Explorer.ExtensibilityTools.dll.
When you set properties with UpdateFileProperties it syncronizes the changes for you. The downside is that ExtensibilityTools doesn't work very well inside an event handler. If you are responding to events from multiple clients (Vault Explorer, Inventor, AutoCAD, etc), you will probably find that it won't work in some of those clients.
This article goes into more detail: http://justonesandzeros.typepad.com/blog/2011/09/autodeskconnectivityexplorerextensibilitytoolsdll.h...
