Utility Design General
EL-Designer
Message 1 of 2 (1,067 Views)
Standard
1067 Views, 1 Replies
05-25-2012 10:50 AM
I am new with this software and haven't tried it yet. I want to know if overhead's or under ground's Standard cover any specefic areas? is there any way to add specefic municipal standards?
Thank you
Active Contributor
jpab
Message 2 of 2 (1,055 Views)
Re: Standard
05-27-2012 07:58 AM in reply to: EL-Designer
The standard shipping version of AUD comes with the RUS Standards for overhead and underground engineering as well as material ordering for both. However since every utility is different and has their own standards AUD is configurable to almost any standard for both Engineering and Material ordering for overhead and underground.
A side note: The engineering values for the wires used in the shipping version came directly from either Alcan or Southwire so almost every utility should be able to use them as is. (all the utility would have to do is change the assembly name to match their standard)
if you want more information about AUD you can contact Linda Viet
Jim Bower
Linda Veit
lindaveit@spatialnet.net
www.spatialnet.net
You are not logged in.
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
