AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
Polyline length - auto fill table - HELP
1 REPLY 1
783 Views, 1 Reply
HI.
I use few poly-lines in my .dwg, is there any option to make table with measurements of poly-lines i.e.. between
A1 - A2 - auto fill length
A2 - A3 - auto fill length
etc.
So when I have to change polyline it will change it's length automatically in table.
Will appreciate...
1 REPLY 1
dave.w
What you describe could be potentially addressed a couple of different ways, depending on exactly how you want the information stored, reported, displayed, etc.
1. Generate material list items for the lines. The lines will need to be actual AUD design features (eg. ducts, conductors, etc.). Use the rule editor to author material rules that generate corresponding items. The quantity or other custom material item attributes can then be populated with the length of the lines. The table will be displayed in the material list editor.
Once material list items are generated you can then insert a TABLE into the drawing, export to csv, or define further reporting layouts using the Report Editor.
2. The Report Editor can be used to generate tabular reports based on any tables in the embedded industry model database, which will include the length values for all linear design features. You will need to refer to the documentation for more information on authoring custom reports.
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
