Material rules in AUD 2014 support an 'Add note' function which generates material note records. These can be viewed in the Material List Editor and displayed in Work Location block attributes via the Style definition used by the Work Location.
The following help articles have more information:
About Material Note Rules
http://docs.autodesk.com/UTLDESN/2014/ENU/filesAUDUG/GUID-DE33047D-B591-4EF9-B97A-D7E36B70A18E.htm
To Define Work Location Styles
http://docs.autodesk.com/UTLDESN/2014/ENU/filesAUDUG/GUID-79CFBA10-85F3-4D9D-8B30-8214F146D72D.htm
To display notes in the work location block attributes, you'll need to define a rule expression for each block attribute. The rule expression can either lookup a particular note by index, or concatenate the notes into a single text expression.
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
