AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
Line Labeling
1 REPLY 1
heberpower
1749 Views, 1 Reply
Line Labeling
When I label a conductor the information is attached to and stored with the line but it does not show up on the screen unless invoked by the "View Facility Information" button. Is there anyway to have the condictor size show up on the drawing? I need all conductors labeled on the screen so they can be plotted with the drawings.
Thanks in advance for any help!
Shawn
Heber Power
1 REPLY 1
jpab
in reply to: heberpower
Shawn,
have you tried and used the UDSCALLOUTcommand?
this command will insert a block with attributes anywhere on the dwg and it can be set (created) with the descrpition of the selected object and or other values.
Jim bower
Spatial Network Solutions
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
