AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
LISP in AUD
4 REPLIES 4
bbeck110
1861 Views, 4 Replies
LISP in AUD
Does anyone have experience in bringing LISP over from AutoCad into AUD? I have some code that I have dropped in and thought it would work. It looks like it is more or less hit and miss. Any help understanding why would be greatly appreciated!
Tags (3)
4 REPLIES 4
rickjohnston
in reply to: bbeck110
Would it be possible to share your LISP routine? There shouldn't be anythiing different between ACAD and AUD as far as LISP code goes. Also are we referencing 2009 version of ACAD and AUD?
Rick...
bbeck110
Thanks for the reply, Rick
To be more specific I meant UDS. My understanding is that AUD is on a similar but different platform thatn straight acad. I don't have the lisp to share. I am getting errors in AUD like: object set to a reference...
rickjohnston
Well this will be certainly hard to give an answer w/o seeing code for this error. That said AUD is built on AutoCAD Map 3D which is built on ACAD so it is essentially the same underlying engine everything bubbles up. Only thing I can think of is the LISP code has something specific to an ACAD that is slightly different in AUD except I cannot think of anything from a LISP perspective.
Would it help to take this off-line to share code? Otherwise not a lot to go on to figure out issue you are seeing.
Rick...
jpab
Depending on what you are trying to do Lisp code that works in autocad will work in AUD (UDS), how ever AUD does store some extended entity data on all of its entities (Lines, blocks, etc.) this could be causing your error, again with out know what you are trying to do its hard to diagnose where the problem lies.
you can look in the AUD_core.lsp and AUD_custom.lsp fiels and you will find examples of lisp code that currently runs in AUD2009 to about UDS2000i
Jim Bower
Spatial Network Solutions
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
