AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
Domain Values
1 REPLY 1
569 Views, 1 Reply
Domain Values
what is domain value and where and  why we use this value.
thanks
1 REPLY 1
Hello Kulfi,
a Domain is a list of possible values for a particular attribute.
Example the attribute Voltage which you see on things like Pole heads, wires and underground cables. This is a domain which would have a list of different voltages like 120/240v, 120/208v and 277/480v each of those is a domain value.
if you do a search of the help file you will see how to add or modifiy a domain.
i hope this helps
Jim
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
