Can any one tell me how to establis data connection.
Hi Kulfi,
Use the MAPCONNECT command to establish a connection to a data source. The command works the same way in both AutoCAD Utility Design and AutoCAD Map 3D. Documentation for this command can be found with your installed product. You can also find the documentation on line. For example:
http://docs.autodesk.com/MAP/2014/ENU/filesMAPLRN/GUID-A6304264-F4A9-4391-AC0D-4ECB568E9639.htm
Bill Dhimitri
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
