does anybody try to export AUD model to Autodesk Infrastrcture Modeler? Do you know if AUD has some functionality to do that (like for example Civil 3D and IMX) or I have to do it similar to AutoCAD Map 3D?
I will be grateful if you could help me.
Thanks in advance!!
what version of AUD are you referring too?
AUD 2009 does not have any built in functionality of its own to export its model to Autodesk Infrastructure Modeler.
However AUD is built on top of map and with the exception of some specialized EED on its lines and blocks so if you can do it in map2009 you can.
I don't know for sure about AUD 2013 but I suspect the answer there is NO as well, you would have to use the Map functionality.
Jim
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
