AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
AUD and Vault?
1 REPLY 1
andrew.warren
1693 Views, 1 Reply
AUD and Vault?
Is there even a need to use Vault with Autodesk Utility Design? I am working with the substation design side but the customer engineering side would like to passably use the Vault and or Product Stream to store data. Is it even needed?
Andy Warren
BCDesign@bellsouth.net
1 REPLY 1
Autodesk Utility Design 2009 is built on AutoCAD Map 3D, which uses Feature Data Objects (FDO) technology to connect to databases such as Oracle, Microsoft SQL Server, etc. For more information, please see the FAQ site:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=734498
The use of Vault or Product Stream would not be required.
Jeff Paquette
Data Management Support Specialist
Autodesk, Inc.
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
