Topobase
Valued Contributor
Message 1 of 1 (592 Views)
Topobase Web 2010 - MapGuide2010/TBWeb/login.aspx
592 Views, 0 Replies
05-06-2010 08:14 AM
Greetings,
When attempting to launch TB Web, (without parameters) as outlined on P.21 of the "topobase_2010_install_configuration_guide.pdf", I get the following returned to the browser:
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
A name was started with an invalid character. Error processing resource 'http://spatial-vm/MapGuide2010/TBWeb/login.aspx'. ...
<%@ page language="C#" autoeventwireup="true" inherits="TBLogin, App_Web_login.aspx.cdcab7d2" culture="auto" uiculture="a...
Any suggestions on what may be causing this behavoir?
Thank you in advance!
Brek
You are not logged in.
Ask the Community
