Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
Report File
1 REPLY 1
aeroslash
426 Views, 1 Reply
Report File
HELLO…HOW ARE YOU? …I WANT TO MAKE A REPORT IN THE TOPOBASE SPACE BUT I NEED TO LINK IT WITH MY ORACLE DATA BASE, I NEED TO DESIGN IT. I WOULD LIKE THAT YOU EXPLAIN ME, STEP TO STEP, TO MAKE MY REPORT. I WOULD LIKE TO SHOW IT FROM AN TOPOBASE FORMS APPLICATION THAT I MADE IT AND I’LL SHOW IT WHEN I PRESS THE BUTTON “TO GENERATE REPORT’, AND THIS WILL VARIANTS TO DEPENDING OF THE OPTION THAT THE USER SELECT TO CONSTRUCT QUERY.
I WILL APRECIATE YOUR HELP AND IF YOU HAVE AN EXAMPLE THAT I CAN NEED JUST LET ME KNOW.
THANKS A LOT.
1 REPLY 1
in reply to: aeroslash
First login to Topobase Admin. That will connect you to the database.
Then open the Workspace you want to create the Report for.
Once the Workspace is open, go to the Document menu and choose Report
Designer.
If you have sample data loaded, you should find an existing report that
might help you to understand the concept. In Oracle, the report definitions
are stored in the workspace's TB_RPT_* tables.
Also check the Autodesk help file for more information.
I hope that gets you going.
Marion Pietsch
Topobase Product Support
Autodesk Consulting
wrote in message news:5582368@discussion.autodesk.com...
HELLO.HOW ARE YOU? .I WANT TO MAKE A REPORT IN THE TOPOBASE SPACE BUT I NEED
FROM AN TOPOBASE FORMS APPLICATION THAT I MADE IT AND I'LL SHOW IT WHEN I
PRESS THE BUTTON "TO GENERATE REPORT', AND THIS WILL VARIANTS TO DEPENDING
LET ME KNOW.
THANKS A LOT.
