Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
Installing Topobase System User (2010)
3 REPLIES 3
1086 Views, 3 Replies
When attempting to install the Topobase System User I encounter a problem when logging into Oracle 11g:
" The User has insufficient privileges. Please login as Oracle user with DBA rights".
Screen captures are in the attached document.
Any suggestions would be greatly appreciated,
Brek
3 REPLIES 3
Shatohin
Try to use SYSTEM oracle user
Thank you for your reply,
I have also tried SYSTEM with the same results. I connect thru SQL Developer with no problem.
Brek
Have solved this issue:
SYS without the "AS SYSDBA" qualifier worked.
