We added several parameters to the proper Revit categories such as Mechanical, Mechanical Flow, etc. but not all of them are exporting to BIM 360 Ops. Is there a limit on the number of parameters that will export from Revit to BIM 360 Ops?
Solved by mdulaney. Go to Solution.
Solved by steven.Mai. Go to Solution.
Parameters in a Revit MEP group will be imported as custom fields in the More Details section. The Revit MEP groups are: Electrical, Electrical – Circuiting, Electrical – Lighting, Electrical – Load, Mechanical, Mechanical – Flow, Mechanical – Loads, and Plumbing. Only shared parameters of type MEP are exported.
If there are other fields to import, you will need to use a spreadsheet.
For more details about the Revit export, please see: https://bim360ops.autodesk.com/blog/preparing-revit-2016-for-handover
Best,
Katie
Hi Michael,
We don't have number limitation, but if the parameter has no value (empty), it wouldn't be imported to ops, we only import parameters with values.
Best Regards,
Steven
Hi @mdulaney,
I'm just checking in to see if you need more help with this. Did the suggestion that @steven.Mai provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
The solution to add data to the parameters prior to exporting from Revit to BIM 360 Ops worked.
The Revit parameters imported into Ops when I added data to them. However, the data entered is place holder data such as zeros for RPMs, AMPs, etc. We have a third party entering the actual data as they collect it. The third party wants to enter the data via spreadsheet where it will be more productive. However, when I exported from Ops to .CSV the custom parameters that show in Ops are not exporting. I've included a screen capture from Ops with the custom field highlighted in yellow and a the exported Ops spreadsheet with the missing fields. Can this issue be solved?
Thank you.
Please reach out to the team at support@bim360ops.com. We will assist you.
Best,
Katie
