HI, I AM UNABLE TO UPLOAD THE FOLDER AND ITS SUB-FOLDERS INTO BIM DOCS. IF PRESENT, PLEASE GUIDE ME.
i,
You cant upload folders to the Plans area. They are created by selecting the three dots and + Add Subfolder. (see image)
You can add folders in the same way under Project Files, but if you have the Desktop Connector installed you can create folders locally on your machine and copy them to desktop connector. These will be replicated in the Project Files location in Docs.
Note: You can create a template project inside Docs to then use again and again. This will save time each time you start a new project.
I hope this helps.
