• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    The Break Room (Non-Technical Discussions)
    For metric dimensioning of holes what would N°8 M12X1D mean?
    571 Views, 7 Replies
    01-30-2013 07:26 PM
    For metric dimensioning of holes what would N°8 M12X1D mean? Sorry that I am not really sure where this would go, a guide to metric hole dimensioning standards would be great.
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: For metric dimensioning of holes what would N°8 M12X1D mean?
    01-31-2013 05:01 AM in reply to: firemandan9
    What's your AutoCAD platform?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    *Expert Elite*
    01-31-2013 05:46 AM in reply to: firemandan9
    I believe an M12 thread is a bolt with an outside diameter of 12mm.  So the question logically arises: are you drilling a hole to tap a thread for this bolt, or a hole that it can pass through without hitting the edges?
    My gut feeling is that you will get the best answer if you ask the person who gave you this spec.
    Do any of these help:
    http://www.efunda.com/DesignStandards/screws/screwm_coarse.cfm
    http://www.efunda.com/DesignStandards/screws/screwm_fine.cfm
    http://www.metrication.com/engineering/threads.htm
    http://en.wikipedia.org/wiki/Metric_thread
    I think the 1D part refers to the hole being the depth of 1 diameter.
    http://www.engineeringsupplies.co.uk/metric-fine-helicoil-insert-pack-1000-p-7453.html
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    Charles_Shade
    01-31-2013 06:22 AM in reply to: troma
    I wonder if the N 8 is the grade of the bolt/screw?
    Your answer is one of the thouroughly researched and complete ones that needs a Kudos.
    *Expert Elite*
    02-04-2013 01:07 PM in reply to: Charles_Shade
    Thanks Charles, but with Google to hand it doesn't take much to find a few interesting sites!
    By the way, on the subject of Kudos, your signature line is a little incongruous on this forum! :smileylol:
    (mine too, I guess)
    *Expert Elite*
    Charles_Shade
    02-05-2013 04:36 AM in reply to: troma
    Should we ask for an alternative signature for non-Kudos Forums?
    You are absolutely right about Google making things easy but you took the time to look and find those sites when the OP did not do so. They looked for the easy answer; hopefully finding it here, and found out that they needed to do some research for themselves. A good local hardware store may have been an answer for them too.
    Rory_M
    02-20-2013 06:26 AM in reply to: firemandan9
    It is a little confusing, and usually you would say M10 x 15 (as an example for a hole that is a 10mm metric thread by 15mm deep)
    The x1D bit is odd, maybe it's a typo or dodgy old drawing that's hard to read
    I don't suppose it actually says No8 M12x10 does it? If it did it would mean:
    No8 is the quantity - 8 off holes
    M12 is the thread - M12 thread (standard is 12mm diameter by 1.75mm pitch)
    x10 Would usually be depth after the thread size, so 10mm deep
    Hope this is useful.
    Rory
    *Expert Elite*
    02-20-2013 07:45 AM in reply to: Rory_M
    Rory, the link I posted earlier show the D referes to the diameter.
    So the depth of the hole is equal to the diameter.
