The Community Room
The Community Room is a space to have conversations about anything you’d like to discuss with your fellow Engineers, Architects, Designers and basically all community members in here.
First Forum Post. Can you find yours?
36 REPLIES 36
Message 1 of 37
Charles_Shade
2276 Views, 36 Replies
36 REPLIES 36
Message 21 of 37
Light_Guy
in reply to: Charles_Shade
http://forums.autodesk.com/t5/AutoCAD-2007-2008-2009-DWG/Double-Click-opens-PEDIT/m-p/1804122#M50964
I was commenting on a post that was similar to the problem I was researching. I started a thread a couple days later which was post #2 having not found my answer.
Paul Hamor
"Always good ships!"
Message 22 of 37
Charles_Shade
in reply to: pendean
I used the first log in that I remembered and then went to the last page of that Search to find it.
When I Searched that log in name I did come up with three choices.
Message 23 of 37
graemev
It all started with an upgrade... but then, like most stories, these things usually start out small.
http://forums.autodesk.com/t5/Autodesk-Inventor/Forcefully-Upgraded-Beyond-All-Recognition-FUBAR/m-p...
Message 24 of 37
ah, okay, I see that now with my older posts...
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
Message 25 of 37
30 mins and yes on a Reply stopping the editing
Message 26 of 37
testsubject
This appears to be my first one when I went by Testsubject_US
http://forums.autodesk.com/t5/AutoCAD-Mechanical/Trouble-using-Autocad-Mech-6-Power-Pack/m-p/365880/...
Looks like I posted earlier than that using my own name
http://forums.autodesk.com/t5/AutoCAD-R12-R13-R14-DWG-Format/Changing-dimension-line-point-size/m-p/...
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 27 of 37
cbenner
in reply to: cbenner
Message 28 of 37
Charles_Shade
Finding those original log-ins are what is interesting.
Wonder why we kept changing names? Probably forgot to write it all down.
Think about how much Autodesk has to maintain because of that.
Message 29 of 37
Light_Guy
We changed names because they changed the website. We all had to re-register and I believe they changed the rules a little in regards to screen names.
Paul Hamor
Message 30 of 37
troma
in reply to: Light_Guy
Hey, here's a challenge for anyone willing: what is the first post ever on these discussion boards? And secondly, what is the first post ever by a user who is still active?
Mark Green
Working on Civil 3D in Canada
Message 31 of 37
derrickmoore
in reply to: troma
I wonder how many thousands of posts vaporized when they ditched NNTP. I do have copies of some posts from way back:
Path: news-autodesk.pilot.net.!news From: christal.elliott@autodesk.com (Christal Elliott) Newsgroups: autodesk.autocad.r14general Subject: Re: Ellipse Arc Bug Date: Mon, 10 Nov 1997 23:18:27 GMT Organization: Autodesk Inc. Lines: 26 Message-ID: <347691a9.7674775@adesknews.autodesk.com> References: <63vuoi$2bm4@news-autodesk> NNTP-Posting-Host: ppp16.laplaza.org Mime-Version: 1.0 Content-Type: text/plain; charset=us-ascii Content-Transfer-Encoding: 7bit X-Newsreader: Forte Agent 1.5/32.451
On Fri, 7 Nov 1997 14:46:24 -0600, "rick moore" <rmoore@barnesarch.com> wrote:
>This is a copy of what I posted recently on the Compuserve Acad forum: > >Unhandled Access Violation Exception at 418520h >This error will come up when following these steps: > >1. Open a new file >2. Draw a random size ellipse by dragging across the screen >3. Draw two lines across the ellipse so that each line intersects the >ellipse twice >4. Break the ellipse by trimming the ellipse between the two lines so that >two ellipse segments are left (Use TRIM to remove the middle section between the two lines you have drawn) >5. Use the "Lengthen, Total" command to change the length of the two ellipse >segments (Select both ellipse segments during one iteration of the Lengthen command) >6. Save and re-open the file > >I found that lengthening just one ellipse segment will not cause the error >and using the "Dynamic" option in the Lengthen command would not cause the >error. > Rick - Reproducible bug - thanks for uploading the sequence of steps! I added a few comments above that assisted me in reproducing this. Christal Elliott //Autodesk Support on the Net//
Message 32 of 37
Murph_Map
First one I found of mine was in July 2000 with a registration date of 2003. (?)  I asked a question and got answers even from Dean back then.
Murph
Supporting the troops daily.
Message 33 of 37
Charles_Shade
in reply to: Murph_Map
Yep the man the legend the Sage answered my first post as well.
Message 34 of 37
steven-g
And guess who answered my first question? My first post was only 4 years ago, http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/DB-field-reference-to-outside-line/m-..., learnt a lot since then.
Message 35 of 37
Ray_Feiler
Message 36 of 37
Ray_Feiler
in reply to: troma
"Hey, here's a challenge for anyone willing: what is the first post ever on these discussion boards? And secondly, what is the first post ever by a user who is still active?"
http://forums.autodesk.com/t5/CAD-Managers/Welcome-to-the-CD-Manager-Cafe-Newsgroup/m-p/727126/highl...
Maybe both
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 37 of 37
Oh... Smiley Sad Frank O...
@Anonymous wrote:
My first post
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/How-to-extract-a-constant-attribute/m-p/876994/highlight/true#M102652
and first response
http://forums.autodesk.com/t5/AutoCAD-R12-R13-R14-DWG-Format/Just-started-drawing-in-3D-Please-Help/m-p/10570/highlight/true#M1040
Melanie Stone
