The Break Room (Non-Technical Discussions)
Non-technical discussions will be held here to give community members a chance to connect and get to know one another.
Valued Contributor
derrickmoore
Message 31 of 37 (361 Views)
Re: First Forum Post. Can you find yours?
05-06-2013 11:57 AM in reply to: troma
I wonder how many thousands of posts vaporized when they ditched NNTP. I do have copies of some posts from way back:
Path: news-autodesk.pilot.net.!news From: christal.elliott@autodesk.com (Christal Elliott) Newsgroups: autodesk.autocad.r14general Subject: Re: Ellipse Arc Bug Date: Mon, 10 Nov 1997 23:18:27 GMT Organization: Autodesk Inc. Lines: 26 Message-ID: <347691a9.7674775@adesknews.autodesk.com> References: <63vuoi$2bm4@news-autodesk> NNTP-Posting-Host: ppp16.laplaza.org Mime-Version: 1.0 Content-Type: text/plain; charset=us-ascii Content-Transfer-Encoding: 7bit X-Newsreader: Forte Agent 1.5/32.451
On Fri, 7 Nov 1997 14:46:24 -0600, "rick moore" <rmoore@barnesarch.com> wrote:
>This is a copy of what I posted recently on the Compuserve Acad forum: > >Unhandled Access Violation Exception at 418520h >This error will come up when following these steps: > >1. Open a new file >2. Draw a random size ellipse by dragging across the screen >3. Draw two lines across the ellipse so that each line intersects the >ellipse twice >4. Break the ellipse by trimming the ellipse between the two lines so that >two ellipse segments are left (Use TRIM to remove the middle section between the two lines you have drawn) >5. Use the "Lengthen, Total" command to change the length of the two ellipse >segments (Select both ellipse segments during one iteration of the Lengthen command) >6. Save and re-open the file > >I found that lengthening just one ellipse segment will not cause the error >and using the "Dynamic" option in the Lengthen command would not cause the >error. > Rick - Reproducible bug - thanks for uploading the sequence of steps! I added a few comments above that assisted me in reproducing this. Christal Elliott //Autodesk Support on the Net//
Murph
Message 32 of 37 (350 Views)
05-06-2013 04:18 PM in reply to: Charles_Shade
First one I found of mine was in July 2000 with a registration date of 2003. (?)  I asked a question and got answers even from Dean back then.
Murph
Supportting the troops daily.
Charles_Shade
Message 33 of 37 (344 Views)
05-06-2013 06:30 PM in reply to: Murph
Yep the man the legend the Sage answered my first post as well.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Valued Mentor
steven-g
Message 34 of 37 (332 Views)
05-07-2013 02:55 AM in reply to: Charles_Shade
And guess who answered my first question? My first post was only 4 years ago, http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/DB-field-reference-to-outside-line/m-..., learnt a lot since then.
Regards Steven Gray
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
Valued Mentor
RayFeiler
Message 35 of 37 (296 Views)
05-24-2013 10:11 AM in reply to: Charles_Shade
Valued Mentor
RayFeiler
Message 36 of 37 (288 Views)
05-24-2013 10:33 AM in reply to: troma
"Hey, here's a challenge for anyone willing: what is the first post ever on these discussion boards? And secondly, what is the first post ever by a user who is still active?"
http://forums.autodesk.com/t5/CAD-Managers/Welcome-to-the-CD-Manager-Cafe-Newsgroup/m-p/727126/highl...
Maybe both
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
Distinguished Contributor
Wanderer-MOTD
Message 37 of 37 (280 Views)
05-24-2013 01:28 PM in reply to: RayFeiler
Oh... :smileysad: Frank O...
RayFeiler wrote:
My first post
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/How-to-extract-a-constant-attribute/m...
and first response
http://forums.autodesk.com/t5/AutoCAD-R12-R13-R14-DWG-Format/Just-started-drawing-in-3D-Please-Help/...
Melanie Perry
***not all those who wander are lost***
http://AUGI.com/Surveys
http://MistressOfTheDorkness.blogspot.com
My defunct profiles:
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/651859
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/644095
You are not logged in.
Ask the Community
