http://forums.autodesk.com/t5/AutoCAD-2007-2008-2009-DWG/Double-Click-opens-PEDIT/m-p/1804122#M50964
I was commenting on a post that was similar to the problem I was researching. I started a thread a couple days later which was post #2 having not found my answer.
I used the first log in that I remembered and then went to the last page of that Search to find it.
When I Searched that log in name I did come up with three choices.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
It all started with an upgrade... but then, like most stories, these things usually start out small.
30 mins and yes on a Reply stopping the editing
This appears to be my first one when I went by Testsubject_US
Looks like I posted earlier than that using my own name
I found 3 posts under my old login name that date back to 2006 sometime... forgot about those.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Finding those original log-ins are what is interesting.
Wonder why we kept changing names? Probably forgot to write it all down.
Think about how much Autodesk has to maintain because of that.
We changed names because they changed the website. We all had to re-register and I believe they changed the rules a little in regards to screen names.
Mark Green
Working on Civil 3D in Canada
I wonder how many thousands of posts vaporized when they ditched NNTP. I do have copies of some posts from way back:
Path: news-autodesk.pilot.net.!news From: christal.elliott@autodesk.com (Christal Elliott) Newsgroups: autodesk.autocad.r14general Subject: Re: Ellipse Arc Bug Date: Mon, 10 Nov 1997 23:18:27 GMT Organization: Autodesk Inc. Lines: 26 Message-ID: <347691a9.7674775@adesknews.autodesk.com> References: <63vuoi$2bm4@news-autodesk> NNTP-Posting-Host: ppp16.laplaza.org Mime-Version: 1.0 Content-Type: text/plain; charset=us-ascii Content-Transfer-Encoding: 7bit X-Newsreader: Forte Agent 1.5/32.451
On Fri, 7 Nov 1997 14:46:24 -0600, "rick moore" <rmoore@barnesarch.com> wrote:
>This is a copy of what I posted recently on the Compuserve Acad forum: > >Unhandled Access Violation Exception at 418520h >This error will come up when following these steps: > >1. Open a new file >2. Draw a random size ellipse by dragging across the screen >3. Draw two lines across the ellipse so that each line intersects the >ellipse twice >4. Break the ellipse by trimming the ellipse between the two lines so that >two ellipse segments are left (Use TRIM to remove the middle section between the two lines you have drawn) >5. Use the "Lengthen, Total" command to change the length of the two ellipse >segments (Select both ellipse segments during one iteration of the Lengthen command) >6. Save and re-open the file > >I found that lengthening just one ellipse segment will not cause the error >and using the "Dynamic" option in the Lengthen command would not cause the >error. > Rick - Reproducible bug - thanks for uploading the sequence of steps! I added a few comments above that assisted me in reproducing this. Christal Elliott //Autodesk Support on the Net//
First one I found of mine was in July 2000 with a registration date of 2003. (?) I asked a question and got answers even from Dean back then.
Yep the man the legend the Sage answered my first post as well.
And guess who answered my first question? My first post was only 4 years ago, http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/DB-field-reference-to-outside-line/m-..., learnt a lot since then.
My first post
and first response
"Hey, here's a challenge for anyone willing: what is the first post ever on these discussion boards? And secondly, what is the first post ever by a user who is still active?"
Maybe both
Oh... Frank O...
@Anonymous wrote:My first post
and first response
