Public Test Forum
blah blah
1 REPLY 1
158 Views, 1 Reply
blah blah
The AutoCAD 2004 Service Pack 1A and the AutoCAD LT 2004 Service Pack 1A should be applied on all supported operating systems and languages. There are separate service packs for the locked and unlocked versions. The service pack is required for any AutoCAD® 2004 extensions. Please see the Readme file for each service pack for a summary of the primary issues they resolve. Note: If you want to use the Autodesk Network Installation wizard to deploy AutoCAD 2004 Service Pack 1A, you must download and run the Autodesk Network Installation Wizard patch. For more information about this patch, see the associated Readme file. If you use the Live Update feature in Communication Center, the service pack version that you need is automatically identified. If you have the same product in multiple languages, all applicable versions will be patched. Separate patches are needed for locked and unlocked versions. If you download the service pack manually, download and install the locked version of the service pack if you are using: An educational or trial version of AutoCAD 2004 or AutoCAD LT® 2004 The International English version of AutoCAD 2004 Download and install the unlocked version of the service pack in all other instances.
1 REPLY 1
adamss
resolve.
versions.
[Attachment: jellyfish.zip]
