Melscript for Softimage toggle isolate...
http://nerd.paololazatin.com/toggle-isolate-selected-in-maya/
Sorry I see that was implemented in Maya, SHIFT i by default.
This is a great helper for softimage users and thanks for all the efforts but I am still missimg the most vital part of isolation of Softimage which is the ability to create new objects after isolation and the newly created objects added in the curent isolation.
Ok I just edit your script to do exactly what I am looking for. Here it is for the others that miss the Softimage way of isolation
//Toggle Isolate Selected in Current Panel
$currentPanel = `getPanel -withFocus`;
$state = `isolateSelect -q -state $currentPanel`;
if ($state == "0")
enableIsolateSelect $currentPanel 1;
isoSelectAutoAddNewObjs $currentPanel 1;
else
enableIsolateSelect $currentPanel 0;
isoSelectAutoAddNewObjs $currentPanel 0;
Actually when you isolate some objects in Softimage, a HUD appears on the top left side of the current viewport which holds some buttons; a minus button which removes the selected objects from the viewport, plus button adds the selected objects to the current isolation and an X button removes the current isolation to see the every objects in the scene normally. Actually as for me, Maya lacks a steamlined workflow as softimage has; most of its tools scattered across the vieport for some reason. Same is true for isolation tool. Softimage does this with a single click of a button but in Maya, one has to isolate objects and add new objects to the curent isolation seperately which kills the artistic aspect of using any 3d app.
Well the functionality is more or less all there, the usual seems to apply - you need to get coding it a bit and make it work the way you want...
Until there is a redesign of all this stuff (if there will be) perhaps stick scripts on your shelf...
There is auto load new objects, Auto load selected (Which is crap as when you go to edit what's selected, ie go into sub-object mode, it loses the selection and they disappear!)
Load selected and add selected and remove selected are there - the user has to make the little plus and minus buttons etc...
So the biggest annoyance is the "Auto load selected objects" drops out objects when you go into sub-object.
You could also make a custom marking menu... like map it to "i" and have all these options pop up when u hold down the key.
