what should be reynolds number for oil used in cooling the mold?
Is 10000 is required or not for oil ?
If required flow rate of coolant will be very high, which is not practical or required
power to pump that flow rate is very high ?
Can anyone answer my question, if any body used oil and simulated the same
with moldflow ?
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
