Hi biricio,
The results are generated as a polygon mesh so the only way to export polygon geometry is via one of the polygon mesh formats, .obj ,.stl, 3ds etc. Moldflow offers STL which I have imported into my CAD software with no problems also for comparison with the math model.
To export a warp model select the deflection analysis you require and click Results > Export Warpage Mesh/Geometry and select the options you need.
Cheers
Danny
