Hi All
I have problem running runner balance in attach
please advice solve this problem or can tell me step by step running runner balance
thanks
-Farid-
it's hard to address the problem with just that pic, however, if you go to the help menu you will find:
** ERROR 1100300 ** Unable to open .RBC file.
An error occurred while accessing the result file (.rbc) from the preliminary filling analysis launched by the runner balance analysis.
Check the disk space and write permissions for the Job Manager temporary directory of the machine where you ran the analysis.
so, I would check my disk space first, and then make sure I have permission to run those kind of analyses...??
Also check this:
Make sure you have an appropiate mesh type as well?
Good luck!
Hugo Herrera
Hi Hugo
thanks for the reply
I have checked my disk space, I have free space 149GB, and I ran in dual domain type mesh.
I predict the problem come from write permision.
but i don't know how to check it, please give me suggestion how to check or fix this issue
-Farid-
Hi All
after almost 1 weeks I tried runner balance, but until right now I still can not ran runner balance and now i got more issue (in attach), I have delete temporary file also
Please some one help me to fix this issue
-Farid-
It seems to me your mesh is too thin.
For the runners apply lengths equal to 2.5 times the diameters.
For the parts, a size around 2.5 times the general thickness (for Midlane and Dual).
Don't forget Moldflow will have to try several filling simulations before finding the good solution.
Good luck.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
