Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
"Allow Docking" option isn't available, a study task panel is floating.
13 REPLIES 13
Message 1 of 14
sj.hwang
1318 Views, 13 Replies
Hi team,
I can't dock a study task panel in ASMI.
I clicked a empty space and right click, It doesn't show a "Allow docking" and "hide" menu.
I search a similar case. "Allow Docking" option isn't available, All panels are floating.
http://forums.autodesk.com/t5/Simulation-Moldflow-Insight/quot-Allow-Docking-quot-option-isn-t-avail...
So I run a cleanreg.exe. then, noting changed.
Can anyone help me this issue?
Kind Regard,
Sujin.
13 REPLIES 13
Message 2 of 14
Hello Sujin,
To see the "allow docking" menu, click up in the empty space next to the Tasks and Tools tabs. You should be able to see it if you click there.
Andrea Heckenberg
LX: Senior Content Developer
DL&S
MAIN +61 3 9720 2088
DIRECT +61 3 9751 8159
FAX +61 3 9729 0433
Autodesk, Inc.
259-261 Colchester Rd.,
Kilsyth, 3137 Victoria Australia
www.autodesk.com
[Description: Description: Description: Description: Email_Signature_Logobar]
Andrea Heckenberg
Content Experience Designer
Message 3 of 14
mayur_dhumal
in reply to: sj.hwang
Hi Sujin,
That original issue was mine luckily, so i can ask you to do this:
As Andrea stated correctly you will need to Right click of your mouse button infront of Tasks & Tools tab (just below the Project bar), you will get 'Allow Docking' option, after that just drag the project window to desired location, it will dock automatically.
This will solve your problem.
Best Regards,
Mayur
Message 4 of 14
sj.hwang
Hi, Andrea, Mayur,
Thank you for your kind response.
the strange thing is when I clicked a next to the task and tools tap, Nothing happened.
However the layer panel and notes panel are normally worked.
So I tried to run cleanreg.exe.
However the "Allow docking" menu still does not show.
Kind Regard,
Sujin.
Message 5 of 14
mayur_dhumal
Hi Sujin,
I hope you are using the similar path as:
Start > Programs > Autodesk > Autodesk Moldflow Insight 20XX > Autodesk Moldflow Insight 20XX Command Shell cleanreg <enter>
Otherwise, Andrea would be the best person to help you in this regards.
Mayur
Message 6 of 14
Hi Sujin,
Do you want to try contacting me directly? Maybe we can screen share and we can try to sort this out? My email address is Andrea.Heckenberg@Autodesk.com
Andrea Heckenberg
Andrea Heckenberg
Message 7 of 14
Hi Sujin,
I did forgot to mention have you tried Autodesk Moldflow Insight 20XX Command Shell with "Run as Administrator'?
Mayur
Message 8 of 14
sj.hwang
Hi, Andrea and Mayur,
Yes. I tried to run as Administrator that file.
How can I share my screen?
My email address is  sj.hwang@ednc.com
Kind Regard,
Sujin.
Message 9 of 14
Halasur
Hi Sujin,
What Mayur explained is correct, it will clean all user interface settings and keep default setting.
Start\All Programs\Autodesk\Autodesk Moldflow Insight 20XX\Tool\ Autodesk Moldflow Insight 20XX Command shell > Cleanreg <Enter>
Regards
Aravind
Message 10 of 14
sj.hwang
Hi Aravind,
Thank you for your help.
I couldn't cleanreg file both Synergy and insight 2014.
and also another customer has same issue.
Can you check this file and send me?
Kind Regard,
Sujin.
Message 11 of 14
mayur_dhumal
Hi Sujin,
You can find the Cleanreg paths:
C:\Program Files\Autodesk\Simulation Moldflow Synergy 20XX\bin\synergycleanreg.exe
C:\Program Files\Autodesk\Simulation Moldflow Insight 20XX\bin\insightcleanreg.exe
Just run these files as 'Run as Admin'
Mayur
Message 12 of 14
sj.hwang
in reply to: mayur_dhumal
Hi Mayur,
There is not cleanreg.exe file.
I using win 7 64 bit Korean version and ASMI 2014 SP2 in English version.
I just called a david lee in ADSK Korea ASE.
He said also he has not cleanreg.exe in 2014 version.
Can you check attached pictures?
and If you possible, Can you send me that file for my email?
sj.hwang@ednc.com
Thank you very much.
Kind Regard,
Sujin.
Message 13 of 14
mayur_dhumal
Hi Sujin,
Show me files starting with 'S' for 'synergycleanreg.exe' & files starting with 'I' for 'insightcleanreg.exe'
Mayur
Message 14 of 14
sj.hwang
Hi everyone,
Thank you for all your help.
It solved.
I contact my customers and all of them fixed. 🙂
Thank you very much!
Kind Regard,
Sujin.
