Discussion Groups
Simulation Moldflow Insight
Active Member
sj.hwang
"Allow Docking" option isn't available, a study task panel is floating.
309 Views, 13 Replies
04-02-2014 07:12 PM
Hi team,
I can't dock a study task panel in ASMI.
I clicked a empty space and right click, It doesn't show a "Allow docking" and "hide" menu.
I search a similar case. "Allow Docking" option isn't available, All panels are floating.
http://forums.autodesk.com/t5/Simulation-Moldflow-Insight/quot-Allow-Docking-quot-option-isn-t-avail...
So I run a cleanreg.exe. then, noting changed.
Can anyone help me this issue?
Kind Regard,
Sujin.
Please use plain text.
Member
heckena
Re: "Allow Docking" option isn't available, a study task panel is floa
04-02-2014 07:44 PM in reply to: sj.hwang
Hello Sujin,
To see the "allow docking" menu, click up in the empty space next to the Tasks and Tools tabs. You should be able to see it if you click there.
Andrea Heckenberg
LX: Senior Content Developer
DL&S
MAIN +61 3 9720 2088
DIRECT +61 3 9751 8159
FAX +61 3 9729 0433
259-261 Colchester Rd.,
Kilsyth, 3137 Victoria Australia
www.autodesk.com
[Description: Description: Description: Description: Email_Signature_Logobar]
Distinguished Contributor
mayur_dhumal
04-02-2014 08:35 PM in reply to: sj.hwang
Hi Sujin,
That original issue was mine luckily, so i can ask you to do this:
As Andrea stated correctly you will need to Right click of your mouse button infront of Tasks & Tools tab (just below the Project bar), you will get 'Allow Docking' option, after that just drag the project window to desired location, it will dock automatically.
This will solve your problem.
Best Regards,
Mayur
Active Member
sj.hwang
04-02-2014 09:38 PM in reply to: sj.hwang
Hi, Andrea, Mayur,
Thank you for your kind response.
the strange thing is when I clicked a next to the task and tools tap, Nothing happened.
However the layer panel and notes panel are normally worked.
So I tried to run cleanreg.exe.
However the "Allow docking" menu still does not show.
Kind Regard,
Sujin.
mayur_dhumal
04-03-2014 03:36 AM in reply to: sj.hwang
Hi Sujin,
I hope you are using the similar path as:
Start > Programs > Autodesk > Autodesk Moldflow Insight 20XX > Autodesk Moldflow Insight 20XX Command Shell cleanreg <enter>
Otherwise, Andrea would be the best person to help you in this regards.
Mayur
Member
heckena
04-03-2014 12:10 PM in reply to: sj.hwang
Hi Sujin,
Do you want to try contacting me directly? Maybe we can screen share and we can try to sort this out? My email address is Andrea.Heckenberg@Autodesk.com
Andrea Heckenberg
mayur_dhumal
04-03-2014 09:13 PM in reply to: heckena
Hi Sujin,
I did forgot to mention have you tried Autodesk Moldflow Insight 20XX Command Shell with "Run as Administrator'?
Mayur
Active Member
sj.hwang
04-06-2014 09:54 PM in reply to: sj.hwang
Hi, Andrea and Mayur,
Yes. I tried to run as Administrator that file.
How can I share my screen?
My email address is  sj.hwang@ednc.com
Kind Regard,
Sujin.
Active Member
Halasur
04-07-2014 05:18 AM in reply to: sj.hwang
Hi Sujin,
What Mayur explained is correct, it will clean all user interface settings and keep default setting.
Start\All Programs\Autodesk\Autodesk Moldflow Insight 20XX\Tool\ Autodesk Moldflow Insight 20XX Command shell > Cleanreg <Enter>
Regards
Aravind
Active Member
sj.hwang
04-09-2014 09:51 PM in reply to: sj.hwang
Hi Aravind,
Thank you for your help.
I couldn't cleanreg file both Synergy and insight 2014.
and also another customer has same issue.
Can you check this file and send me?
Kind Regard,
Sujin.
